Hello i was wondering if i could do the fallowing for a fast rollback if im doing a upgrade
On maintenance i click on copy files
Source running config
Destination flash file system: and i put here any name for example runningconfig (do i need to specify .cfg???? )
This will save me a backup of my running config
Now let say my config file got corrupted
I would do this depending on which partition i had the old version(if it was the partition 0:0 then:
on the cpboot prompt:
cpboot> bootf 0:0
And also cpboot> setenv cfgfile runningconfig.cfg
cpboot> saveenv
cpboot> reset
This would be only if the problem is that the config file is corrupted or the image got corrupted or doesnt work somehow. I would go to the last version i had with the old config file. Besides that i would do my complete flash backup, just like always before doing anything, i mean if everything looks bad and i need to call TAC.
Carlos
