Rouge AP containment via Wirless network
  • 1.  Rouge AP containment via Wirless network
    Posted Mar 19, 2017 05:42 AM
    Dear allfriends, and experts,
    Im buiding lab and demo some features of IPS/IDS with RF Protect license.
    In my understand have two ways to Rouge containment.
    1. On Wired network ( Plug into an AP unauthorized to Wired network.
    => Air montir will block fake BSSID, and  the AM ignores the client (done)
    2. On the wireless network
    AM see a hotspot and hotspot broadcast a random SSID, i set this learned from AM to Rouge.
    But, i dont see anything changed, client still can connect to Rouge AP and can do anything.
    Please clearly for me, In wirelss network,, Aruba can ignores client ? Because when i read documents, it said can ignores AP rouge via wired and wireless netowrk.
    Thank you so much,
    Lee
  • 2.  RE: Rouge AP containment via Wirless network
    MVP EXPERT
    Posted Mar 19, 2017 06:49 AM
    Have you turned Rogue containment on?
    (config) #ids unauthorized-device-profile default
    (IDS Unauthorized Device Profile "default") #rogue-containment
  • 3.  RE: Rouge AP containment via Wirless network
    Posted Mar 19, 2017 06:58 AM
    Hello Zalon0,
    I configed, so it's only affected when i plug an AP into Wired network.
    But on wireless network its dose not efftected.
    Thank you so much, any idear for me, this is the first time i working with IDS/IPS
    Lee
  • 4.  RE: Rouge AP containment via Wirless network
    Posted Mar 20, 2017 03:00 PM
    1. try show ap monitor ap-list ap-name <yourAP>.  In my AP, DOS was disable, so you can see two rogues SSIDs: NINCOM and NINCOM-GUEST.
    2: show ids unauthorized-device-profile default: you can see the rouge containement is false
    Enable the containement, then you will see rougue be DoS or tarpit
