We are a school dist over a lager area in Wa State I have aprox 800 ap's and somone out there is using a rouge dhcp server on my open network, Is there a way to prevent this on the controller, ie dhcp snooping ect as on a network switch.
You could create an ip access-group on your interface only allowing DHCP from your DHCP servers
Also apply the rule user any udp 68 on all your ACL defined under your user-roles , if you use the logon-control it should be define there as well.
