Rouge management - Instant APs via AirWave GUI Config
  • 1.  Rouge management - Instant APs via AirWave GUI Config
    Posted Jun 22, 2015 10:37 AM
    Hi!
    Trying to confirm - Is it possible to manage Rouge containment/isolation via AirWave is the Instant APs are being managed via GUI Config? Documentation that I have shows that changing RAPIDS classification only affects Aruba/Cisco Controlled platforms.
    Eitherway - Any best practices for this?
    Thanks!
  • 2.  RE: Rouge management - Instant APs via AirWave GUI Config
    Posted Jun 25, 2015 02:37 AM
    HI Friend,
    No. it also applicable to VC (IAP) also.
  • 3.  RE: Rouge management - Instant APs via AirWave GUI Config
    Posted Jun 25, 2015 10:09 AM
    What configuration would be needed to allow a user to contain a SSID via AirWave if it is determined to be rouge (In the same AirWave Instant GUI configuration model).
