Wired Intelligent Edge
Routed links with VLANs and can’t ping the Management IP...
  • 1.  Routed links with VLANs and can’t ping the Management IP...
    Posted Jun 11, 2019 05:23 PM
    Hi all!
    I am kind of new to Aruba and learning... I have a question though and can’t figure out what I’m missing...
    I have 3 2930f switches in 3 locations that are linked together. A and b are connected on a vlan with each interface having an ip, b and c are connected in a vlan with each interface having an ip and same for C and A.
    I can ping and remotely connect to the vlan IPs, but I cannot ping or remotely connect to the switches with the management IP... any suggestions?
  • 2.  RE: Routed links with VLANs and can’t ping the Management IP...
    MVP GURU
    Posted Jun 12, 2019 02:02 AM
    can you share the config ?
    do you have a schema ?
    do you don't have forget default gateway ? or enable management vlan ?
  • 3.  RE: Routed links with VLANs and can’t ping the Management IP...
    Posted Jun 25, 2019 06:46 PM
    Basically we have two 2930F.
    Interface 28 on both is the interface connecting the two.
    Each switch has a different IP on VLAN 1.
    We are using a vlan with a /30 subnet that has interface 28 untagged  on both.
    Traffic flows fine, but I can only ping and remotely connect to the IP of the interface 28 (We are using RIP as well).
    I am trying to figure out how I can ping the IP of VLAN 1 which I am not able to do, but all else is good... If that makes sense...
  • 4.  RE: Routed links with VLANs and can’t ping the Management IP...
    Posted Jun 26, 2019 01:10 PM
    Greetings!
    Is there a route from your management system to the VLAN 1 IP address on each of the switches you're trying to access? You may need to check other switches and/or routers to verify that these routes are being properly redistributed via RIP.
    If that route is there, next verify that there is a route back to the management system IP/subnet from the switch itself. Use the 'show ip route' command in the switch CLI:
    switch# show ip route
        IP Route Entries
      Destination        Gateway         VLAN Type      Sub-Type   Metric     Dist.
      0.0.0.0/0          10.5.7.1        57   static               1          1
      10.5.7.0/24        Mgmt            57   connected            1          0
      127.0.0.0/8        reject               static               0          0
      127.0.0.1/32       lo0                  connected            1          0
    Verify that you either have a specific route that includes the subnet where the management system is located, or that the default router is capable of routing back to that system.
  • 5.  RE: Routed links with VLANs and can’t ping the Management IP...
    Posted Oct 08, 2019 12:03 PM
    It has been a little bit, I am still working on this though. I am going to check the routing.
    The set up is 3 switches. A, B and C. A is the main one. A is connected to B by a /30 subnet. B is connected to C with a /30 subnet as well. The switches are running RIP. The two interfaces that connect the switches are setup as untagged on VLAN 1 only.
    I can ping VLAN 1 from B and C back to A. If I am on any of the switches, I cannot ping VLAN 1 on the other switch though... I saw the a message about the default gateway, but I cannot do that unless I disable the routing.
  • 6.  RE: Routed links with VLANs and can’t ping the Management IP...
    MVP GURU
    Posted Oct 08, 2019 03:18 PM
    if routing is enable you need to use ip static route 0.0.0.0...
  • 7.  RE: Routed links with VLANs and can’t ping the Management IP...
    Posted Nov 08, 2019 11:35 AM
    Once I connected a device to the switch and put it on that VLAN I was able to ping the management IP/ VLAN...
  • 8.  RE: Routed links with VLANs and can’t ping the Management IP...
    MVP GURU
    Posted Nov 09, 2019 04:05 PM
    do you have check the (default) gateway ?
