Hello everyone,
I'm looking for some help configuring a routed port on switches running AOS-S. As far as I know, there is no support for configuring actual routed interfaces on switches running AOS-S. By routed interface, I mean a port equivalent to a router port, with no VLAN involved. This would be the equivalent of using the "no switchport" command on a Cisco switch. This feature is supported on switches running AOS-CX, but as far as I know, the lowest model capable of running this OS is the 6300 series. Am I wrong here? If that's the case, my only option is to create a VLAN/SVI, assign an IP address, and add a port to that VLAN to simulate a routed port on AOS-S, right? FYI, buying other hardware is not an option.
I'm asking because I'm configuring intersite connections (campus network) and I want to configure L3 interfaces (no L2, no trunking) to route between sites. Has anyone set up point-to-point links using VLAN/SVIs to route? Are there any cons compared to using a routed port?
