last person joined: 2 hours ago
Router question
  • 1.  Router question
    Posted Dec 23, 2012 12:29 AM
    We have been using the Aruba Instant APs with the Ubiquiti routers.  Al, of of clients and APs get plugged into a Cisco SG300 switch.  What do you recommend for a router in this configuration?  I have hushed an Apple Airport extreme, Ciscand and a uniquit, but I am not really happy with any of them.  They all seem to o key last 6-12 months.  Any recommendations?
    Also, where are you guys doing DHCP, at the APs or at the router?
    mike
  • 2.  RE: Router question
    Posted Dec 23, 2012 09:17 AM
    How many users are there?
    For a good deployment you need
    Firewall that is plugged to the internet
    Then on the firewall on his internal port you plug in a Switch Layer 3
    And then you plug in the Distribution or access switches(depending on how big is your bussiness) guess is small so you could plug the IAPs to the Acess switches...
    How small is your bussiness?
    At least i got a deployment with instants on a small bussiness of 40 users
    I got a Fortigate 80C  which is nice for Webfilter, firewalll, app control ETC its all in it
    Plugged to that i got a small core switch of 10 ports(10/100/1000) an alcatel POE,  which where im pluggin the uplink of the other access switch which is a 48 port switch  and the servers
    I plugged the Instant to the core switch
    I got fortigate FSSO integrated with AD, also got the Instant integrated with an NPS server 802.1x (with roles)and also the swtiches with 802.1x(with something similar than role works the same)... all the managment with nps
    Everything is integrated with AD so to manage everything he just need to change groups on the AD...
    ITs a small bussiness with all the securiy and centralized managment on the AD groups.   Its interesting this deployment and they are happy with it
    Anyways this is just an example with the brands i manage,
    You could change the Firewall brand to another  but if you gonna buy a UTM firewall check the Gartner quadrant! fortinet is the one leadering it.  On switches you can change them with another good brand!  could be cisco but it will be more expensive, or the guys on the forum can advice you on this...  You could use a Aruba Switch also used as stand alone and do all this... and if you buy a controller later you can integrate EVERYTHING with NPS and all the rules will be in  single point....
    Just imaging that the role you using apply for wired users, wireless and vpn clients.... but you need the controller for that.
    Anyways the basic is
    Firewall--Switch core---Layer 2 switches
    And of course vlans and all that...
    PD:
    If i cannot mention other brands in my post please just advice me moderators ill edit the message and ill not mention other brands again
  • 3.  RE: Router question
    Posted Dec 23, 2012 11:30 PM
    It's a residence.  There are about 40-50 devices always on the network,  when his family comes in town, there can be about 20 more devices.
