Just hoping someone could help with a problem we are having with our switch config.
Basically we have a stack of 4 3810m’s. Port 1/1 is connected to a Sophos firewall. Ports 1/2 and 2/2 are connected to ports 49 and 50 on a 2930f
The Sophos firewall has an ip of 172.16.98.2 and this can be pinged from the core stack. The core stack can also ping the outside world.
However the 2930f can’t ping the Sophos or the outside world.
The default gateway on the 2930f is set to 10.0.0.1 so any traffic outside the 10.0.0.0/24 subnet should route through the core and then the ip route setting on that switch should route basically everything through to the Sophos.
Below are the configs for the switches. Any ideas?
Running configuration:
; hpStack_KB Configuration Editor; Created on release #KB.16.07.0003
; Ver #14:01.4f.f8.1d.fb.7f.bf.bb.ff.7c.59.fc.7b.ff.ff.fc.ff.ff.3f.ef:4e
stacking
member 1 type "JL075A" mac-address 9020c2-e28000
member 2 type "JL075A" mac-address 9020c2-e1bc80
member 3 type "JL075A" mac-address 9020c2-e2f880
member 4 type "JL075A" mac-address 9020c2-e20600
exit
hostname "CORE"
trunk 1/2,2/2 trk1 lacp
ip route 0.0.0.0 0.0.0.0 172.16.98.2
ip routing
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
member 1
exit
member 2
exit
member 3
exit
member 4
exit
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1/1
untagged 1/3-1/16,2/1,2/3-2/16,3/1-3/16,4/1-4/16,Trk1
ipv6 enable
ipv6 address dhcp full
exit
vlan 98
name "VLAN98"
untagged 1/1
ip address 172.16.98.1 255.255.255.0
exit
vlan 120
name "TEMP"
tagged Trk1
ip address 10.0.0.1 255.255.255.0
exit
spanning-tree Trk1 priority 4
; JL256A Configuration Editor; Created on release #WC.16.07.0003
; Ver #14:01.4f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:02
hostname "Aruba-2930F-48G-PoEP-4SFPP"
module 1 type jl256a
trunk 49-50 trk1 lacp
ip default-gateway 10.0.0.1
no ip source-route
vlan 1
name "DEFAULT_VLAN"
no untagged 1
untagged 2-48,51-52,Trk1
ipv6 enable
exit
vlan 120
name "TEMP"
untagged 1
tagged Trk1
ip address 10.0.0.2 255.255.255.0
exit
