Here are the show commands:
(CSS_S1) #show ip route
Codes: C - connected, R - RIP
O - OSPF, O(IA) - Ospf inter Area
O(E1) - OSPF Ext Type 1, O(E2) - Ospf Ext Type 2
M - mgmt, S - static, * - candidate default
D - DHCP
Gateway of last resort is 10.99.0.1 to network 0.0.0.0 at cost 39
S * 0.0.0.0 /0 [39] via 10.99.0.1
S 10.10.0.0/16 [0] via 10.255.254.10
S 10.11.0.0/16 [0] via 10.255.254.11
S 10.12.0.0/16 [0] via 10.255.254.12
S 10.13.0.0/16 [0] via 10.255.254.13
S 10.14.0.0/16 [0] via 10.255.254.14
S 10.15.0.0/16 [0] via 10.255.254.15
S 10.16.0.0/16 [0] via 10.255.254.16
S 10.17.0.0/16 [0] via 10.255.254.17
S 10.18.0.0/16 [0] via 10.255.254.18
S 10.19.0.0/16 [0] via 10.255.254.19
S 10.20.0.0/16 [0] via 10.255.254.20
S 10.21.0.0/16 [0] via 10.255.254.21
S 10.22.0.0/16 [0] via 10.255.254.22
S 10.23.0.0/16 [0] via 10.255.254.23
S 10.24.0.0/16 [0] via 10.255.254.24
S 10.25.0.0/16 [0] via 10.255.254.25
S 10.26.0.0/16 [0] via 10.255.254.26
S 10.27.0.0/16 [0] via 10.255.254.27
S 10.28.0.0/16 [0] via 10.255.254.28
S 10.29.0.0/16 [0] via 10.255.254.29
S 10.30.0.0/16 [0] via 10.255.254.30
S 10.31.0.0/16 [0] via 10.255.254.31
S 10.32.0.0/16 [0] via 10.255.254.32
S 10.50.0.0/16 [0] via 10.255.254.50
D - DHCP
S 10.51.0.0/16 [0] via 10.255.254.51
S 10.52.0.0/16 [0] via 10.255.254.52
S 10.53.0.0/16 [0] via 10.255.254.53
S 10.54.0.0/16 [0] via 10.255.254.54
S 10.55.0.0/16 [0] via 10.255.254.55
S 10.56.0.0/16 [0] via 10.255.254.56
S 10.70.0.0/16 [0] via 10.255.254.70
S 10.71.0.0/16 [0] via 10.255.254.71
S 10.72.0.0/16 [0] via 10.255.254.72
S 10.73.0.0/16 [0] via 10.255.254.73
S 10.74.0.0/16 [0] via 10.255.254.74
S 10.75.0.0/16 [0] via 10.255.254.75
S 10.76.0.0/16 [0] via 10.255.254.76
S 10.96.0.0/16 [0] via 10.255.254.96
S 10.97.0.0/16 [0] via 10.255.254.97
S 10.98.0.0/16 [0] via 10.255.254.98
C 10.99.0.0/20 is directly connected: vlan1
C 10.99.0.10/32 is directly connected: vlan1
C 10.99.16.0/20 is directly connected: vlan2
C 10.99.16.1/32 is directly connected: vlan2
C 10.99.32.0/20 is directly connected: vlan3
C 10.99.32.1/32 is directly connected: vlan3
C 10.99.48.0/20 is directly connected: vlan4
C 10.99.48.1/32 is directly connected: vlan4
C 10.99.64.0/20 is directly connected: vlan5
D - DHCP
C 10.99.64.1/32 is directly connected: vlan5
C 10.99.255.0/24 is directly connected: vlan45
C 10.99.255.1/32 is directly connected: vlan45
C 10.255.254.0/24 is directly connected: vlan20
C 10.255.254.99/32 is directly connected: vlan20
(CSS_S1) # show interface-config vlan 1
vlan "1"
Parameter Value
Interface OSPF profile N/A
Interface PIM profile N/A
Interface IGMP profile N/A
Interface shutdown Disabled
mtu 1500
IP Address 10.99.0.10/255.255.240.0
IPv6 Address N/A
IPv6 link local Address N/A
DHCP client Disabled
DHCP relay profile N/A
Interface description N/A
Thanks for your help,
