Wired Intelligent Edge
RPVST ARUBA CX 8320 "No STP instance present".
This thread has been viewed 24 times
  • 1.  RPVST ARUBA CX 8320 "No STP instance present".
    Posted Mar 25, 2020 05:12 PM
    Hi community.
    I ´m loss with a issue in my Aruba 8320.
    When i enable spanning-tree mode rpvst with those command:
    spanning-tree
    and  then i put the command "show spanning-tree" it´s say the follow:
    CORE# show spanning-tree
    Spanning tree status : Enabled Protocol: RPVST
    Extended System-id : Enabled
    Ignore PVID Inconsistency : Enabled
    Path cost method : Long
    Current Virtual Ports Count : 0
    Maximum Allowed Virtual Ports : 2048
    No STP instance present.
    NO STP INSTANCE PRESENT, why does say this?
    when i try to configure a priority for some vlan it's say the same.
    CORE(config)# spanning-tree vlan 102 priority 15
    Error : STP instance not present for one or more VLANs.
    how can i enable rpvst instance in the aruba 8320?
  • 2.  RE: RPVST ARUBA CX 8320 "No STP instance present".
    MVP GURU
    Posted Mar 26, 2020 05:34 AM
    Before set priority, if you use :
  • 3.  RE: RPVST ARUBA CX 8320 "No STP instance present".
    Posted Jan 16, 2021 09:07 AM
    Is there any way to enable spanning tree for all active VLANs in the switch now? Is it required to enables spanning tree instance for each VLAN after creating the VLAN? This is an extra step in VLAN creation process that need to be don eon every and each switch.
    Ahmad Enaya
  • 4.  RE: RPVST ARUBA CX 8320 "No STP instance present".
    Posted Jan 18, 2021 06:01 AM
    No you have to specify the VLANs:
    If you have contiguous vlan (ex: vlan 10 to VLAN 99), you can use the command
    spanning-tree vlan 10-99
    For non-contiguous VLANs, just enter the list of VLANs in a single command like below:
    switch-A(config)# sh vlan
    VLAN Name Status Reason Type Interfaces
    1 DEFAULT_VLAN_1 up ok default lag256
    1115 VLAN1115 up ok static lag1,lag256
    1125 VLAN1125 up ok static lag2,lag256
    switch-A(config)# spanning-tree vlan 1,1115,1125
    Vincent Giles
  • 5.  RE: RPVST ARUBA CX 8320 "No STP instance present".
    MVP GURU
    Posted Mar 26, 2020 10:44 AM
    Hi, as written by Alexis you need to set the VLAN(s) on the RPVST+ mode:
