Wired Intelligent Edge
RSTP convergence issues on HPE Aruba Switches
  • 1.  RSTP convergence issues on HPE Aruba Switches
    Posted Jun 29, 2020 04:48 AM
    Hi Everyone,
    When I test RSTP convergence I note ping IP -t replies are intermittent, can someone advise what causes this behavior given the following configuration?
    The Arubu switches are 2930M JL322A series and have AV hardware attached.
    All switches:
    igmp filter-unknown-mcast
    We are using VLAN 11 for the AV hosts, which has the command:
    ip ipmg
    SW-0-1 (Core Layer 2/3 switch)
    CST Root Port: This switch is root
    SW-0-5 (Edge AV switch)
    CST Root Port:48
    SW-0-6 (Edge AV switch)
    CST Root Port:48
    A laptop connected to SW-0-6 and has an DHCP allocated IP address and a ping <IP> -t running.
    SW-0-5 and SW-0-6 are connected via an alternate port (47).
    bpdu filters exclude data VLAN uplink ports and router outbound port
    spanning-tree
    spanning-tree 40 bpdu-filter
    spanning-tree 45 bpdu-filter
    spanning-tree 46 bpdu-filter
    spanning-tree 47 bpdu-filter
    spanning-tree 48 bpdu-filter
    no spanning-tree bpdu-throttle
    spanning-tree trap new-root root-guard loop-guard
    spanning-tree priority 0 force-version rstp-operation
    SW-0-5 and SW-0-6
    spanning-tree
    spanning-tree force-version rstp-operation
    Hope someone can assist. Thank you.
  • 2.  RE: RSTP convergence issues on HPE Aruba Switches
    MVP GURU
    Posted Jul 01, 2020 05:01 PM
    Do you are sure it is a issue with STP ? what do you have on the log ?
