Network Management
run a command from Airwave not working when local controller auth-mgmt disable
  • 1.  run a command from Airwave not working when local controller auth-mgmt disable
    Posted Aug 02, 2012 09:48 AM
    I recently disabled local management authentication on our controller as we wish to use TACACS+. Since then, when I try to use the "run a command" function in Airwave,  Airwave is unable to login to the controller.
    Is there a way around this so that I don't have to enable local management authentication on my controllers ?
  • 2.  RE: run a command from Airwave not working when local controller auth-mgmt disable
    Posted Aug 02, 2012 03:35 PM
    create an account in Tacacs that Airwave can use.
