Running ADP /tmp/master No such file or directory
This thread has been viewed 27 times
  • 1.  Running ADP /tmp/master No such file or directory
    Posted Apr 30, 2015 10:12 AM
    Hi there,
    We are seting up a lab environment with an Aruba 3200 controller ArubaOS 6.3.1.7 and a new AP-105. When powerup, the AP keep rebooting with the message in subject.
    Below is the log:
    APBoot 1.4.0.3 (build 37726)
    Built: 2013-03-21 at 20:13:41
    Model: AP-10x
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
    01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
    Net: eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    Using eth0 device
    TFTP from server 172.23.4.61; our IP address is 172.23.4.200
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
    Retry count exceeded; starting again
    ARP Retry count exceeded; starting again
    Using eth0 device
    Loading: T #################################################################
    done
    Bytes transferred = 4724140 (4815ac hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x02000000 ...
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (4655272 bytes)
    Loading .data @ 0x812708b0 (32 bytes)
    Clearing .bss @ 0x812708d0 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...........................................
    ú
    Aruba Networks
    ArubaOS Version 6.3.1.7 (build 43819 / label #43819)
    Built by p4build@corsica.arubanetworks.com on 2014-05-19 at 16:53:18 PDT (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 121856k/131072k available (1931k kernel code, 9088k reserved, 752k data, 3784k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=17819136
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ................................................................................................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    Domain Name: arubanetworks.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count 400
    AG7100: Max rx descriptor count 252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: 9c:1c:12:ca:8a:fe
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 5236)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    Starting watchdog process...
    Got all network ag7100_ring_alloc Allocated 4800 at 0x8070e000
    params from APboag7100_ring_alloc Allocated 3024 at 0x8771b000
    ot env. SkippingAG7100: cfg1 0xf cfg2 0x7014
    DHCP
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000 AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    Writing 4
    172.23.4.200 255.255.254.0 172.23.4.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    Please help.
  • 2.  RE: Running ADP /tmp/master No such file or directory
  • 3.  RE: Running ADP /tmp/master No such file or directory
    Posted Apr 30, 2015 10:54 AM
    Hi Tim,
    The issue has been resolved, the master ip was missing in the AP configuration.
    Thank you for your help.
  • 4.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 06:32 AM
    Can you repost the link? it seems to be broken and I am having this issue with an AP325 right now. Thanks
    Running ADP...
    Done. Master is
    [  143.727522] Restarting system.
    [  143.751546] Going down for restart now
  • 5.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 06:55 AM
    What discovery method are you using for your access point?
  • 6.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 06:57 AM
    I believe I am using a DHCP alias: aruba-master
    I am not the only admin to this system though, so someone may have enable ADP by accident. It is enabled on my master at the moment but I don't want to turn it off if it isnt the problem.
    Jay
  • 7.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 07:02 AM
    Do you mean DNS alias?  You should stop the AP at the apboot> prompt and type "dhcp" to see if it finds a controller.  If not, your network is not configured properly for discovery.
  • 8.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 07:11 AM
    Yes sorry, I will try that and see how it goes.
    Thanks!
  • 9.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 14, 2017 09:37 AM
    Ok, so ADP is enabled on my master, disabled on the locals. I still see the same log on the console of the CLI. This is the first AP deployment in Latin America for us. the US APs work fine, but these keep going into that reboot loop.
    10.249.122.161 255.255.255.0 10.249.122.26 10.249.122.1
    Done. Master is
    The system is going down NOW !!
    [  163.857482] Restarting system.
    [  163.881474] Going down for restart now
    APBoot 1.5.5.8 (build 57191)
    Built: 2016-11-04 at 17:53:10
    Model: AP-32x
    DRAM:  491 MB
    SF:    Detected MX25U3235F with page size 64 kB, total 4 MB
    Flash: 4 MB
    NAND:  132 MiB
    PCIE0: link up
    PCIE1: link up
           00  00  168c  0040 00002   00 00000004 00000000 00000000 00000000
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0, eth1
    Radio: qca9990#0, qca9990#1
    Reset: warm
    FIPS:  passed
    apboot>
    Things to look for? the DNS alias pings @ my master address.
    At a loss here. AP reset didnt change results.
  • 10.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 15, 2017 04:36 AM
    What do you get when you type "dhcp" at the apboot> prompt?
  • 11.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 15, 2017 10:34 AM
    I get this:
    apboot> dhcp
    eth0: link up, speed 100 Mb/s, full duplex
    DHCP broadcast 1
    DHCP broadcast 2
    *** Unhandled DHCP Option in OFFER/ACK: 44
    *** Unhandled DHCP Option in OFFER/ACK: 46
    *** Unhandled DHCP Option in OFFER/ACK: 241
    DHCP IP address: 10.249.122.162
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 10.249.122.1
    DHCP DNS server: 10.249.4.243
    DHCP DNS domain: la.tech.cnb
    apboot>
  • 12.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 15, 2017 06:44 PM
    do you have a DNS entry for aruba-master.la.tech.cnb?
  • 13.  RE: Running ADP /tmp/master No such file or directory
    Posted Sep 16, 2017 07:42 AM
    Yes, it points to the master and I have tested it from the vlan the APs are in, it responds as it should
