Network Management
Running Airwave on a Laptop
  • 1.  Running Airwave on a Laptop
    Posted Jul 09, 2012 07:00 AM
    Hi Gents
    In a recent Airwave class we ran airwave on a Laptop.  I am looking at demo'ing airwave at a clients site for a few weeks (Free of Charge), and would like to do this as cheaply as possible.  Has anyone had experience of running airwave on a Laptop, and if so, what exactly were you using, and how was the experience.
    Appreciate your time.
    Regards
    Robbie
  • 2.  RE: Running Airwave on a Laptop
    Posted Jul 09, 2012 10:52 AM
    This is from my experience:
    Airwave can run on a laptop for only the smallest of networks (maybe 8 APs), due to the memory as well as the high disk IO requirements.
  • 3.  RE: Running Airwave on a Laptop
    Posted Jul 09, 2012 01:12 PM
    I want to use this for monitoring a Cisco core, and access layer switches to monitor the amount of Data flowing through it.  I suppose this is just not possible then?
    There must be a fairly cheap way to achieve this?
  • 4.  RE: Running Airwave on a Laptop
    Posted Jul 09, 2012 01:13 PM
    Well, how many devices are we talking and what are the specs on your laptop?
  • 5.  RE: Running Airwave on a Laptop
    Posted Jul 09, 2012 01:53 PM
    Maybe 6 Switches - Core i5, 8gb Ram, 5400rpm drive.  Does it make a difference whether the switches are access layer or core switches?
  • 6.  RE: Running Airwave on a Laptop
    Posted Jul 09, 2012 01:55 PM
    If it is just 6 objects with a laptop with those specs, you should try it.  Make sure you give the VM as much memory as you can.
    Does not make a big difference with the switches....
