Rx drops on AP60
  • 1.  Rx drops on AP60
    Posted Feb 23, 2014 06:04 AM
    Hi All,
    with the following command I see many RX drops on AP60:
    show ap debug counters ap-name
    Interface counters
    Interface          Rx_pkts             Rx_errors           Rx drops             Tx_pkts           Tx_errors  Tx_drops   Resets
    wifi0                  22721705         0                           20737118           4918620         17931       0                  0
    Someone can help me to understand the root cause of the Rx drop counter?
    Thanks and Best Regards
    Gian
  • 2.  RE: Rx drops on AP60
    Posted Feb 23, 2014 07:02 AM
    What version of ArubaOS is this, because that parameter does not match that command...
  • 3.  RE: Rx drops on AP60
    Posted Feb 23, 2014 11:13 AM
    We have a 6000 Controller running 3.4.5.1 OS.
    About your experience what could be the root cause for RX_drops? (Interference, external antennas, antennas cable.....?)
    Thanks and Best Regards,
    Gian
  • 4.  RE: Rx drops on AP60
    Posted Feb 23, 2014 11:16 AM
    Gian
    All of the above.
    What is your problem?
  • 5.  RE: Rx drops on AP60
    Posted Feb 23, 2014 11:29 AM
    I would like to understand the cause of this RX_drops on all APs.
    There are some advanced debugs or suggestions to help me?
    Gian
  • 6.  RE: Rx drops on AP60
    Posted Feb 23, 2014 01:45 PM
    You're unlikely to be able to identify the root cause that way. In simple terms, the AP is telling you the frame it received was unreadable. Probably the transmission was interrupted, or corrupt by background aspects, but the AP doesn't know why.
    If your controller and APs were a lot newer, the spectrum analysis might help. But from a practical standpoint, I'd suggest you're a long way from that being an option!
    So, you should look at the following.
    1. How many clients are connected on that AP on average? Is it busy? If so, this might explain the drops due to contention.
    2. Are all APs doing this, or just one? If it's all of them, it suggests configuration optimization is in order. If it's just a few, that suggest localized issues, maybe interference or noise.
    3. What is the physical environment the AP is in? Near a lift, kitchen or industrial equipment? All of these might cause interference and drops.
    Start from there, and consider physically visiting the AP and its surroundings if you're not sure.
  • 7.  RE: Rx drops on AP60
    Posted Feb 24, 2014 09:51 AM
    Thanks for your reply.
    Here below the output. In the manual I read that "RX frames dropped" simply is the number of frames that AP dropped. I should find another value (or values) that added make up this number. No ?
    ------------------- Receive Specific Statistics
    Last SNR 32
    Last ACK SNR 34
    Frames Received 60640570
    Good Frames 60138494
    Bad Frames 502076
    Channel Busy 1s 0
    Channel Busy 4s 0
    Channel Busy 64s 0
    Discarded Events 60100259
    ARM Scan Frames 0
    Rx Data Frames 12627556
    Rx Data Bytes 0
    Null Data Frames 0
    Rx Mgmt Frames 43953398
    Control Frames 3557540
    Frames To Me 4433067
    Broadcast Frames 51279731
    Beacons Received 43751610
    Probe Requests 110403
    Rx Probe Responses 33834
    Rx RTS Frames 113652
    Rx CTS Frames 9811
    ACK Frames 3434077
    PS Poll Frames 0
    CRC Errors 502076
    PLCP Errors 497227
    Rx Frames Dropped 52167942
    PHY Events 59348699
    RADAR Events 0
    RX Interrupts 118321325
    RX Overrun 0
    Rx 6 Mbps 52608340
    Rx 9 Mbps 7855
    Rx 12 Mbps 132601
    Rx 18 Mbps 94273
    Rx 24 Mbps 3622889
    Rx 36 Mbps 3672536
  • 8.  RE: Rx drops on AP60
    Posted Feb 24, 2014 10:14 AM
    Rx Frames Dropped is perfectly normal if it is high.  Only "interesting" frames that are unicast are forwarded to the switch, so a high Rx frames dropped could mean alot of broadcat/multicast/management traffic that was observed but  not forwarded.
    Instead of digging into counters that could mean multiple things, why don't we talk about your setup?
    - Did this ever work?  If so, what changed?
    - What clients are you using?
    - What encryption are you using?
    - How are the access points mounted and how far apart?
