Anyone have the integration document or writeup on integration between S1500 and IAPs?
Refer to 7.3 MAS user-guide doc, "Chapter 38 Aruba AP Integration"
if you don;t have that doc, same can be download from aruba support site:
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=12270
-Vinay
Also check out chapter 33 of the Instant 4 User Guide.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12853
Thanks Vinay and Tim. Real easy to get things done withj all the experts here.
