Wired Intelligent Edge
S1500 won't save startup config
  • 1.  S1500 won't save startup config
    Posted Nov 12, 2019 11:53 AM
    Hello, After setting up a s1500 switch using the quit setup through the CLI I am not able save the startup config.
    I issue a copy running config to startup config command that says it completed sucess fully. When I show the startup config it still show the defauls. I recent purchased 3 used s1500s and they all exhibt the same symtoms.
    Anyone out there having a simular problem?
  • 2.  RE: S1500 won't save startup config
    Posted Nov 13, 2019 04:24 AM
    Can you try 'write mem' instead of copy running startup? I use 'wr mem' and never had this issue. I know many do the same, so it may not have been noticed for a while.
    Can you reboot the switch to see if which config is actually loaded?
  • 3.  RE: S1500 won't save startup config
    Posted Nov 13, 2019 11:51 AM
    Yeah, I tried wr mem as well. Indicated it was saving the configuration , but startup config still not updated.
    A reboot take the switch back to default mode and has t be reconfigured.
