I appreciate the response but that implies that SW2 which is a Wifi Netgear router, does all the inter-vlan routing. The lab will have 4 VLANs but more dynamic VLANs if / as I set up demos.
As such, what I would liked to have done is simply run a command such as
Inter-VLAN Routing (arubanetworks.com) Or add some set of static routes without pushing all VLANs to use GW of Netgear
(sw0) #show ip route
Codes: C - connected
O - OSPF, O(IA) - OSPF inter area
O(E1) - OSPF external type 1, O(E2) - OSPF external type 2
O(N1) - OSPF NSSA type 1, O(N2) - OSPF NSSA type 2
M - mgmt, S - static, * - candidate default
D - DHCP
Gateway of last resort is 172.16.100.1 to network 0.0.0.0 at cost 1
S * 0.0.0.0 /0 [1] via 172.16.100.1
C 172.16.100.0/24 is directly connected: vlan100
C 172.16.100.254/32 is directly connected: vlan100
(sw0) #
90% of traffic will be VLAN 100 (172.16.100.0/24) to internet , but to have routing would be very useful.
Jeremey Wise
Original Message:
Sent: Sep 03, 2021 06:30 AM
Subject: S2500-48P-4x10G - Router Intervlan Routing
The chapter 18 in the MAS User Guide (L3-routing) should have all the information.
Create VLAN interfaces, configure DHCP/DHCP-relay if your clients need to get an IP, configure the default route.
Then make sure your SW2 can route back to the MAS for the VLANs 101-104 IPs, and that it performs NAT for those ranges as well.
The MAS switch does support NAT as well, but I would leave NAT as close to the ISP as possible.
Original Message:
Sent: Sep 02, 2021 07:06 PM
Yes.. I know older switch, but its what I have to work with.
Firmware: 7.4.1.12
Looking for example of use of L3 basic Inter-VLAN routing table. VLAN ID is third Octet. GW for environment is 172.16.100.1 which is on wifi/ ISP router.
Jeremey Wise
