In that case you probably want to do all routing on your pfsense.
Can you share what you configured? And in addition the output of 'show vlan' 'show trunk' 'show user-table' and 'show mac-address-table'?
You should have a switching-profile with switchport-mode trunk on the port that goes to your firewall, and one in access mode (default, so no command), access-vlan and trusted (unless you do want to do authentication).
Note that the S2500 MAS is end-of-sale and end-of-support. For production networks it may be better to find an alternative that still has support options.
Original Message:
Sent: Apr 09, 2022 12:53 AM
Subject: S2500 and pfSense
I am having a bit of a hard time accomplishing my network setup.
Firewall: pfSense
Switch: Aruba S2500 48P
I have setup VLANs on the pfSense and now am trying to apply those VLANs to ports on the S2500. I have achieved setting a switching-profile to a port. I am struggling to allow this port to receive an IP address via a DHCP server running on the pfSense. Can someone please help point me in the correct direction?
Trying to apply interface vlan 80 and ip address/gateway 14.1.80.0
Things I have done, in no particular order:
- setup ip helper-address, didn't work
- tried to run the interface vlan 80 with ip address 14.1.80.3, when I do this though, I lose the route through the trunk to my firewall because it's now trying to use the interface VLAN 80, I think?
- factory reset
- tried to run the interface VLAN 80 with dhcp-client active, no luck
- factory reset
Anyway, I have been hitting my head against the wall for some time. If anyone can point me towards the proper way to do this I would appreciate it.
- Assign VLAN to port
- Allow device to receive IP via DHCP on pfSense
- Inter VLAN routing on the switch doesn't particularly matter to me right now, but would be nice
Thank you
Joe Swanson
