S2500 in dorm rooms with AirGroup
  • 1.  S2500 in dorm rooms with AirGroup
    Posted Dec 06, 2012 05:05 PM
    We are looking at installing S2500s on each floor for our dorm room switches, but have a couple questions:
    1. We are hoping to block Peer to Peer traffic on the wired network, on the 3600 controller there is that option on the wifi side, can that carry over on the wired side too?
    2. Would AirGroup allow a student to then connect their devices together and allow the devices to interect like normal, or will it be limited to services like AirPrint and such?
    I have to say if the AP93H offered 5Ghz also we would have put one of those in every room!
    Thanks!
    Jake
    #3600
  • 2.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 06, 2012 08:17 PM
    The 93H is dual-band. You can choose 2.4 or 5 GHz.
  • 3.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 07, 2012 11:51 AM
    You are right, the issue I had is that it is a single radio.  It has been awhile since I looked at the 93H and forgot my specific issue.
  • 4.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 07, 2012 05:05 AM
    AirGroup is specially for mDNS based services, is that what you are looking for or are you looking broader?
  • 5.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 07, 2012 10:29 AM
    It would be nice to have something that allows a user to have all of their devices in their own little cloud without any restrictions while still securing their gear from another user.
  • 6.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 08, 2012 07:05 AM
    can understand the use case, but i believe AirGroup isn't going to solve all that for you. though with what is around it might be extended to something like that. could always file it as a suggestion with Aruba.
  • 7.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 10, 2012 01:30 PM
    Thanks for the insight on the AirGroup.
    Does anyone know about the blocking peer to peer traffic on the switches?
  • 8.  RE: S2500 in dorm rooms with AirGroup
    Posted Dec 10, 2012 01:54 PM
    Jake,
    The Mobility Access Switches do not currently support the "deny inter user traffic" command like the Mobility Controllers. I believe this is what you were referring to in your original post correct?
    However If you are just trying to block P2P between your students (in fact all traffic between them) versus P2P traffic between your students and the outside world (which is more tricky), you could craft an ACL attached to the physical ports or user-roles to block the student L3 networks from each other and only allow access to their respective default gateways.
    Best regards,
    Madani
