s2500 Slot 0 Power Supply Failed
  • 1.  s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 02:52 PM
    Anyone seen this alarm?
    It started after upgrading to 7.3. I found that the configuration tab was not working so I downgraded to 7.2. The alarm has been active on both revs after a reboot.
    How can I clear the alarm?
  • 2.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 02:59 PM
    Can you send the output of "show inventory"? If this is a PoE model, I suspect that there was an anomaly detected and so the Power Supply has shut off PoE until you physically remove the power cable and re-attach.
    Best regards,
    Madani
  • 3.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:01 PM
    That could be. Right now i'm setting it up in our lab and I have it plugged into a 7010 controller. Both device supply poe.
    (ArubaS2500-24P) #show inventory
    Show Inventory
    System Card Slot : 0
    SC Serial # : BY0011308 (Date: 05/27/14)
    SC Model Name : ArubaS2500-24P
    Mgmt Port HW MAC Addr : 00:0b:86:a7:fd:c1
    HW MAC Addr : 00:0b:86:a7:fd:c0 to 00:0b:86:a7:fd:ff
    CPLD Version : Rev: 2.4 (0x2.4)
    PoE Firmware Version : 0.0.0 (Build: 0)
    CPU Assembly # : 2010152C (Rev: 06.00)
    CPU Serial # : ME21000073 (Date: 05/24/14)
    Power Supply : Failed (580W)
    : 12V System Voltage Ok
    : 56V PoE Voltage Failed
    Power Supply Serial # : IP058T440RGT (Date: 04/22/14)
    Power Supply Model No : 2510064
    Power Supply Vendor Model No : IPSN-580APA1 (Rev: 48.48)
    Console Card Assembly # : 2010111C (Rev: 01.00)
    Console Card Serial # : CE21000422 (Date: 05/27/14)
    PoE Card Assembly # : 2010108C (Rev: 01.00)
    PoE Card Serial # : PE21000613 (Date: 05/27/14)
    System Temperature : CPU Temp : 46 C
    : DPE Temp : 46 C
    : DDR Temp : 37 C
    : PSU Temp0 : 36 C
    : PSU Temp1 : 38 C
    : Exhaust Temp : 38 C
    : Mid Temp : 41 C
    : Ambient Temp : 36 C
    : Console Card Temp : 27 C
    System Voltages : 3300mV Sense : 3376.0 mV
    : 2500mV Sense : 2480.0 mV
    : 1800mV Sense : 1808.0 mV
    : 1000mV Sense : 992.0 mV
    : 900mV CPU : 912.0 mV
    : 1200mV Sense : 1216.0 mV
    : 5000mV 5VDD : 4998.0 mV
    : 5000mV 5VSB : 4974.0 mV
    System Fan Tachometers : Power Supply Fan 0 : 4639 RPM (Low Speed)
    : Power Supply Fan 1 : 4639 RPM (Low Speed)
    : FAN 0 : 4770 RPM (Low Speed)
    : FAN 1 : 5000 RPM (Low Speed)
  • 4.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:03 PM
    Yeah, this is the specific line of interest:
    If you disconnect all connections and un-plug/re-plug the power cord, does the switch go back into that state?
    Madani
  • 5.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:04 PM
    reseating the ethernet cable turned the alarm off. Not a big deal current if thats how its designed.... I just wanted to make sure it wasn't a RMA situation.
  • 6.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:17 PM
    Yes, if we're receiving power inbound to a port, we shut-off the 56v rail to protect the switch. The 7010 shouldn't be recognizing us as a device to power up. Did you say just re-seating the cable corrected it?
  • 7.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:23 PM
    It did, but the alert came back after a minute or so of plugging it back in.
    I removed the ethernet and connected via fiber to avoid the issue.
    I did think it was odd that the poe was triggered by the 7010. Both devices had poe lights active.
  • 8.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:24 PM
    If you disable PoE on the respective interconnect ports, do you still see the issue? Do you have Prestandard PoE enabled?
  • 9.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:25 PM
    Both devices are default except for an IP address.
  • 10.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 06, 2014 03:29 PM
    I can play with the poe settings when I get a chance.
  • 11.  RE: s2500 Slot 0 Power Supply Failed
    Posted Oct 23, 2014 09:37 AM
    Just ran into the same issue on an S1500 with a 7010 controller.
    We had a brownout and my S1500 rebooted, the 7010 did not. Since the link went down the 7010 then offered power to the S1500.
    When the S1500 came up the show inventory listed the power supply as failed and the 56V poe as failed.
    The S1500 showed this output from show poe (My uplink is port 0/0/0)
    (Aruba7010) #show poe
    PoE Status
    Port       Status  Voltage(mV)  Current(mA)  Power (mW)
    GE 0/0/0   On      55878        85           4700
    I went into the 7010 and issued:
    interface gigabitethernet 0/0/0 no poe
    (Aruba7010) (config-if)#show poe
    PoE Status
    GE 0/0/0   Off     N/A          N/A          N/A
    Once I did that the S1500 immediately started sending power to the ports and all is well!
    Power Supply                  : Present (580W)
                                  : 56V PoE Voltage Ok
    Thanks Madani!
