Did you change in the console properties? (Using putty or Hyper Terminal) Make sure under Flow Control select "None"
If you keep the configuration on hardware you are going to get the error below which I assume is the " ARUBA" screen..
After you change the configuration you will see the regular menu..
Giovanni Saldarriaga
