Wired Intelligent Edge
S3500 Data Switches
  • 1.  S3500 Data Switches
    Posted Jan 09, 2014 09:03 AM
    All,
    Please Help..............
    We have a S3500 in production in our own office. We are trying to set it up with VLAN's and IP routing. I have the commands, but the switch is running 7.0.2.0. We know we have to upgrade to 7.3.0.1 which we will be doing that tonight.
    My questions are:
    I keep getting this error when I try and interface VLAN 2.
    "Error: Maximum number of VLAN interface(s) supported is 1".
    Why?
    1. How do I set up a DHCP relay on a VLAN. It looks like I have to setup a profile for the relay.
    2. How do I setup an IP on the VLAN. I have the commands, but its not working due to the error above
    3. How do I make sure the VLAN's route between each other
    Are there added commands from code 7.0.2.0 to 7.3.0.1?
    Any help would be appreciated.......
    Wally
  • 2.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:06 AM
    7.0.2.0 is a very, very early version of code. I would definitely upgrade the switch before configuring anything.
    Once you upgrade to a more recent version of code, here are some of the commands:
    1)
    create a dhcp-relay-profile
    interface-profile dhcp-relay-profile "RELAY-PROFILE-DATA-B"
        helper-address 10.10.10.10
     apply the dhcp-relay-profile to the vlan interface
    interface vlan "11"
       pim-profile "default"
       ip address 10.10.8.1 255.255.255.0
    2)
    (stack) (config)# vlan 2
    (stack) (config)# interface vlan 2
    (stack) (vlan "2")# ip address 172.16.10.1 255.255.255.0
    3) Inter-vlan routing is enabled by default between SVIs/RVIs on the same stack.
  • 3.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:11 AM
    I totally agree, but are my bullet points correct?
    Also, how do I get a switch port to associate to the VLAN. I know I can do it thru the GUI, but I don't see a command for the CLI line.
    Thanks for the quick response too........
    Wally
  • 4.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:12 AM
    Tom,
    i didnt see your responses after......this is great.....Thank you......
  • 5.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:17 AM
    So if you are using trusted ports (no authentication), you would do the following:
    1) create a switching-profile for the VLAN:
    interface-profile switching-profile "VLAN100-DATA"
       access-vlan 100
    2) create an interface-group containing the switchports you'd like to have this configuration
    interface-group gigabitethernet "TRUSTED-GROUP-1"
       apply-to 0/0/0,0/0/2,0/0/4,0/0/6,0/0/8,0/0/10
       lldp-profile "LLDP-PROF-1"
       poe-profile "POE-PROFILE-1"
    For untrusted ports (authentication and user-roles), you attach the VLAN to the user-role. There is a bit more setup with this as you need to setup authentication servers.
    Create a user-role and attach a VLAN to the user-role:
    user-role MEDIA-PLAYER
     vlan 200
     access-list stateless mDNS-AirGroup
     access-list stateless DLNA-AirGroup
     access-list stateless allowall-stateless
    Create an interface-group containing the switchports you'd like to have this configuration. This interface-group will have more configuration because of authentication.
    interface-group gigabitethernet "UNTRUSTED-GROUP-1"
       apply-to 0/0/1,0/0/3,0/0/5,0/0/7,0/0/9,0/0/11
       aaa-profile "UNTRUSTED-AAA-1"
       no trusted port
  • 6.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:22 AM
    Thanks so much. I haven't really programmed a Aruba data switch before. I appreciate all the help. You are on point. I appreciate it........Have a great day.....................
    Wally
  • 7.  RE: S3500 Data Switches
    Posted Jan 09, 2014 09:40 AM
    The profile-based configuration takes some getting used to but in the end, it saves a lot of time and makes configuration changes very easy.
