Wired Intelligent Edge
last person joined: 7 hours ago
S3500 dhcp-relay
  • 1.  S3500 dhcp-relay
    Posted Nov 19, 2012 04:58 PM
    I need to setup dhcp relay on a S3500 switch running Version 7.1.3.0
    I believe I have it set up right and that there is a problem in my dhcp server but just in case I got it wrong or I'm missing something I thought I better put up this post.
    First set up the relay profile
    (ArubaS3500-24-POE) (config) # interface-profile dhcp-relay-profile 1
    (ArubaS3500-24-POE) (dhcp relay profile "1") #helper-address 172.16.1.254  <-- Your dhcp server ip address
    Then apply the profile to the vlan interface
    (ArubaS3500-24-POE) (config) #interface vlan 3
    (ArubaS3500-24-POE) (vlan "3") #dhcp-relay-profile 1
    (Aruba-24-POE_GREllington3) (vlan "3") #exit
    Then of course do a wr mem.
    Am I missing anything because it sure isn't working.....
    Thanks guys !!!
  • 2.  RE: S3500 dhcp-relay
    Posted Nov 19, 2012 06:25 PM
    Do you also have an IP interface on that VLAN? Otherwise the configuration looks correct.
    Best regards,
    Madani
  • 3.  RE: S3500 dhcp-relay
    Posted Nov 19, 2012 08:50 PM
    Yes I have an IP address assigned to the interface.
    Ok. Thanks. Like I said I think there is a problem with dhcp server.
    Just wanted to confirm the config on the switch.
  • 4.  RE: S3500 dhcp-relay
    Posted Nov 20, 2012 02:04 PM
    REMOVED
    Suggestion was already answered above.
  • 5.  RE: S3500 dhcp-relay
    Posted Sep 25, 2014 12:30 PM
    Team,
    This thread was very handy, however I am new to 3500 (Aruba) and need to change to a new DHCP server... can some one post how to remove the profile? I am unable, says, profile in use, but no vlan interface is assigned to it..
    Started with:
    interface-profile dhcp-relay-profile DHCP-RELAY-Profile1 <-- Old Profile
    helper-address 10.x.x.xx5 <-- Old dhcp server ip address
    Created a new profile with new helper IP...
    Removed the dhcp profile from vlan interface
    assigned new profile to the VLAN interface...
    Unable to remove old profile now?
    Thanks for your help...
  • 6.  RE: S3500 dhcp-relay
    Posted Sep 25, 2014 12:32 PM
    Is the profile tied to another interface or group?
  • 7.  RE: S3500 dhcp-relay
    Posted Sep 25, 2014 01:16 PM
    Ahhh yes it was... removed ok now. Thanks
