This support reference for HP switch 5500G (AKA 3Com 5500G-EI) is exactly the error I’m getting on our S5500-24G EI switch A5500
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=4177876&prodTypeId=12883&objectID=c02601694
The software versions (3Com’s ?) bear no relation to the HP version numbers.
In our case the issue started after about 180 days uptime.
A reboot has resolved the issue (at least temporarily – presumably cleared the dynamic table)
This other reference describes to a related error but has the ‘correct’ software versions indicated:
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=4174795&prodTypeId=12883&objectID=c02601502&printver=true
It also refers to the dhcp relay hand disable command in versions 2202P15 or later
So, I downloaded the latest, H3C S5500EI-CMW520-R2210, software & bootrom and updated my test(spare) switch
– BUT the dhcp relay hand disable command is not available/valid in V5.20R2210 !
Display Version records below.
Does this mean the original software error has been corrected in R2210 and the dhcp relay hand disable command is no longer necessary ?
Will Bootrom 710 and software H3C S5500EI-CMW520-R2210 ‘cure’ the issue on production switches ?
Thanks, Mac
Switch that had the Issue:
[LR_Lcn_Core]disp ver
H3C Comware Platform Software
Comware Software, Version 5.20, Release 2202
Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-28C-EI uptime is 0 week, 3 days, 1 hour, 49 minutes
H3C S5500-28C-EI with 1 Processor
256M bytes SDRAM
32768K bytes Flash Memory
Hardware Version is REV.C
CPLD Version is 002
Bootrom Version is 609
[SubSlot 0] 24GE+4SFP Hardware Version is REV.C
Test Switch:
[LR_Lcn_CoreCopy]disp ver
Comware Software, Version 5.20, Release 2210
Copyright (c) 2004-2011 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-28C-EI uptime is 0 week, 0 day, 1 hour, 15 minutes
256M bytes SDRAM
CPLD Version is 002
Bootrom Version is 710
#a5500#DHCPrelay
