I have the following setup :
LAN1 >>> SWitch1 >>> Router1 >>> Internet
LAN2 >>> SWitch2 >>> Router1 >>> Internet
Now i want to use Same AP for Both LANs to provide WIFI Coverage , is that Doable ?
The question is do you need your wireless clients to have access to services on both Lans or just the internet. If it is just the internet, you should be fine...
Are you using a controller or Instant?
