Same SSID across different branches with Aruba Instant
  • 1.  Same SSID across different branches with Aruba Instant
    Posted May 22, 2017 09:45 AM
    We are planning on implementing Aruba Instant APs in a company's (4) different branches as space and number of users is small.
    Their main concern is that they need to have same SSID across all different branches in a way that when a user is once connected to the SSID in any branch, they will be connected to the same SSID in the second branch without requiring to re-enter password.
    How can this be configured within Aruba IAP?
  • 2.  RE: Same SSID across different branches with Aruba Instant
    Posted May 22, 2017 09:47 AM
    If you are using 802.1x the supplicant automatically logs the user in..
  • 3.  RE: Same SSID across different branches with Aruba Instant
    Posted May 22, 2017 09:54 AM
    Dear Joseph,
    They currently utilize PSK authentication.
  • 4.  RE: Same SSID across different branches with Aruba Instant
    Posted May 22, 2017 12:46 PM
    You need to create SSID with same name for all those 4 locations with same psk.
    Milind Yashwantrao
  • 5.  RE: Same SSID across different branches with Aruba Instant
    Posted May 22, 2017 10:30 AM
    How are you managing your IAPs ?
    Using Airwave / Central or Local Management?
    Get Outlook for iOS
  • 6.  RE: Same SSID across different branches with Aruba Instant
    Posted May 23, 2017 02:03 AM
    It will be through AirWave or Aruba Central.
  • 7.  RE: Same SSID across different branches with Aruba Instant
    Posted May 23, 2017 03:39 AM
    You can push config to IAP from Airwave or Aruba Central both.
    For  Aruba Central  you need to purchase Aruba Central Device Management Subscription .
    If you want to use Aruba Airwave then you need to purchase per device license .
    Milind Yashwantrao
  • 8.  RE: Same SSID across different branches with Aruba Instant
    Posted May 23, 2017 04:07 AM
    Hi Milind,
    So it's just a matter of pushing the config and it should work even with PSK authentication?
  • 9.  RE: Same SSID across different branches with Aruba Instant
    Posted May 23, 2017 06:07 AM
    As SSID name and psk are same so you dont require to make any changes at client devices if they move from one location to other.
    Milind Yashwantrao
