same SSID but different role prelogon
  • 1.  same SSID but different role prelogon
    Posted Feb 26, 2019 11:31 PM
    Hi all,
    can we create different AP Group with same SSID name, but different prelogon role guest in each group ?
  • 2.  RE: same SSID but different role prelogon
    Posted Feb 27, 2019 02:56 AM
    The "initial role" is defined in the AAA profile:
    Virtual AP:
      SSID Profile
      AAA profile
    So you would clone your Virtual AP profile and then change the AAA profile in the new Virtual AP:
    config t
    wlan virtual ap <new virtual AP name>
    clone <old virtual ap name>
    That would give you a new virtual AP.  You would just change the AAA profile under that new Virtual AP and "save as" a different AAA profile.  In the new AAA profile, you would then change the initial role.  You would then add the new Virtual AP to your new ap-group.
    I am sure there is probably an easier way, and I hope that made sense.
  • 3.  RE: same SSID but different role prelogon
    Posted Feb 27, 2019 02:59 AM
    noted,
    i will try that,
    thanks a lot sir
