SAML login with OneLogin
  • 1.  SAML login with OneLogin
    Posted Oct 25, 2019 11:42 PM
    Has anyone been able to setup OneLogin as the SAML provider for Aruba Central?  I've gone through the Catalog of apps on OneLogin and i'm only able to find "Aruba Partner Center" which is a forms based login, not SAML.
  • 2.  RE: SAML login with OneLogin
    Posted Oct 26, 2019 02:38 PM
    Hey man....
    @munozj wrote:
    Has anyone been able to setup OneLogin as the SAML provider for Aruba Central?  I've gone through the Catalog of apps on OneLogin and i'm only able to find "Aruba Partner Center" which is a forms based login, not SAML.   9Apps VidMate apk VLC
    i am also trying to do the same ......do let me know if u find any solution...!
