Hi Everyone,
I am new to procurve switches and have been tasked to setup a SAN fabric.
Currently have to 2910al switches.
Have created a VLAN for the SAN and enabled flow-control and Jumbo frames for the SAN.
Config So Far
VLAN 1 - Management VLAN
IP Gateway - 10.0.0.99
IP Address - 10.0.0.20/24
Untagged - 20 - 24
VLAN 10 - SAN VLAN
IP Address 192.168.0.20/24
Untagged 1-19
I have enabled the IP Route command to be able to route through traffic.
I currently have the server connected from 1 NIC with IP - 192.168.0.100 VLAN 10. The other NIC is with IP 10.0.0.100 IP Gateway 10.0.0.1 connected to the LAN
I need to be able to route the SAN software to the email system on the 10.0.0.0/24 network so that it can alert me when there are issues with the SAN.
I also then need to be able to add in my other switch into the fabric so that the 2 switches are connected to the SAN and the server is connected to the 2 switches. However when i do this i have issues with connecting to the SAN box. I have tried enabling RSTP on both switches with no luck.
Can anyone help?
#SAN#2910al#VLAN
