Hi All,
I'd like to start this discussion to see if anyone else who has a similar network can give any feedback on how they have their network setup. Here's what we have:
1. We have an Aruba Wifi network + Clearpass with Employee, student, BYOD, and Guest wifi. All on different subnets.
2. we have Apple TV in the classrooms that all wifi networks have access to via Airgroup.
3. we have Airprint printers. different WiFi networks have access to different printers. We use a server called Presto that advertise the printers via DNS. This allows us to control which WiFi get access to which printers.
So here's the issues I'm having and trying to solve:
1. it's just not very reliable. We have problems with incomplete lists of Apple TV. If you tend to use one Apple TV often, there's a good chance that is the one that will not advertise for you.
2. or another thing we see with Apple TV advertisements is lets' say room 20 Apple TV will not be available for 4 people, but the 5th person can see it.
3. another issue we have is printers appearing offline for MacOS and iOS devices. Most of the time toggling the wifi fixes it, but not always. Sometime you have to reboot the device and sometimes even that doesn't bring the printer back.
4. the other issue I'm facing is printer sharing on the BYOD wifi. If a BYOD user has a printer shared, it advertises to the entire network. Then users try to install that printer which is causing a bunch of confusion.
So if anyone can give any feedback about their use with Airgroup and maybe some successes or design ideas they have. We have never had much luck with Airgroup. and since Airgroup is not required for our printing solutions I'm suspicious it's adding another layer of complexity we don't need.
