Network Management
SCP backup to Airwave
  • 1.  SCP backup to Airwave
    MVP
    Posted Apr 27, 2017 06:48 AM
    Got a couple Clearpass hardware appliances and a virtual Airwave server. A snapshot of the Airwave VM is taken every night so I'm thinking about using the Airwave server as a backup target for Clearpass. Basically I just want to SCP Clearpass files to Airwave.
    So, what directory could I use for this? Evidently, I do not want this directory to be touched/erased/whatever by Airwave or during/after Airwave upgrades.
  • 2.  RE: SCP backup to Airwave
    MVP
    Posted Apr 27, 2017 08:24 AM
    The aruba controller backup script found at https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Use-AirWave-script-to-regularly-back-up-Aruba-controllers uses  /var/airwave/custom/ so I suppose that's the correct path to use.
  • 3.  RE: SCP backup to Airwave
    Posted Apr 27, 2017 08:55 AM
    Hi Koen,
    We could use /alternative directory aswell. During upgrade process it wont tuch this directory.
    Create a custom directory and proivde path in clearpass.
    Pavan
  • 4.  RE: SCP backup to Airwave
    MVP
    Posted Apr 27, 2017 11:20 AM
    Thank you for the info Pavan.
    Seemed an easier directory to spot (and remember) so I changed the controller script and clearpass config to save there.
    Just so I know, does it matter one way or the other? /alternative vs /var/airwave/custom?
  • 5.  RE: SCP backup to Airwave
    Posted Apr 27, 2017 12:32 PM
    We could use any one of the directory, its up to you!
    Regards
    Pavan
