SCP from a controller to a Mac
  • 1.  SCP from a controller to a Mac
    Posted Oct 24, 2013 02:36 PM
    I wanted to ask if anyone has been able to successfully SCP files from a controller to a Mac? I have not had any luck so far. I have remote login enabled on my Mac and can SSH to my Mac from another PC. Not sure what I am missing. When I try to do an SCP file transfer from the controller it appears to start and then fails and shows "Error copying file".
    Not sure what I am missing. I know it's not the controller as it works with a Windows SCP server. I'm new to the Mac environment so I don't know the tricks of the trade so to speak.
  • 2.  RE: SCP from a controller to a Mac
    Posted Oct 25, 2013 02:18 PM
    SCP uses port 22 (SSH). If you've enabled remote login for SSH in turn it enables SCP.
    Can you post your SCP command? Are you providing a username/password?
  • 3.  RE: SCP from a controller to a Mac
    Posted Oct 25, 2013 02:48 PM
    I have run into this with Macs before.  Are you seeing PAM authentication errors in the system log on the Mac?  You can fix this by editing the /etc/sshd_config file on the Mac and enabling the PasswordAuthentication option. Change it from this:
    #PasswordAuthentication no
     to this:
    PasswordAuthentication yes
     and restart the SSHD service:
    sudo launchctl stop com.openssh.sshd
  • 4.  RE: SCP from a controller to a Mac
    Posted Oct 25, 2013 03:35 PM
    Thank you very much for the procedure. I was pulling my hair out trying to figure out what the problem was. It worked like a charm.
  • 5.  RE: SCP from a controller to a Mac
    Posted May 07, 2014 10:54 AM
    Hello again,
    I have a new Mac now and this process isn't working on it. Do you know if something changed in the Mac OSX 10.9.x? I have remote login enabled, all users allowed and I changed the ssh_config file. Still seeing the PAM messages.
    Chris
  • 6.  RE: SCP from a controller to a Mac
    Posted May 07, 2014 10:56 AM
    satx71 did you restart sshd?
  • 7.  RE: SCP from a controller to a Mac
    Posted May 07, 2014 10:58 AM
    I need to put on my dunce hat.... I was chaning the ssh_config not the sshd_config. Guess I need to get my glasses checked.. :)
    Thanks anyway folks.
