Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Network Management
Community Home
Discussion
22K
Library
782
Events
0
Members
1.3K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Script exist error - "missing close-brace"
1.
0
Kudos
Carl Verner Staugaard
Posted Jul 15, 2022 10:37 AM
view attached
Reply Privately
Options Dropdown
Hi
I downloaded new software on my IMC for switch type 2930F, wc_16_11_0004.swi and tried to update one of my manny switches - but get a fail, see Attachment
Attachment(s)
Script exist error.txt
1 KB
1 version
2.
RE: Script exist error - "missing close-brace"
0
Kudos
pak4458
Posted Aug 16, 2022 01:47 PM
Reply Privately
Options Dropdown
Hi try below method
Login to iMC, go to Service -> Configuration Center -> Software Library
Check if required firmware file is available in library. If not, use "Add" button to load firmware file in IMC. If available, select the file and click on "Deploy"
Default file transfer mode (Service>Configuration Center>Options) needed to be changed from TFTP to SFTP. Under Single Device Transfer Mode select device and set that device on SFTP mode.
Click on "Select device", browse using type or IP address. Select appropriate device.
Device will be visible under the list. Use appropriate one or more device types.
Click next, it checks and shows if sufficient space is available in memory.
Under "Set task attributes", give any name or it will take automatic one. Schedule time or select "Immediately".
Verify summary of the task and click "Finish"
Select task and click "Execute" if required
Once the task is executed successfully, check firmware on device.
Original Message
Original Message:
Sent: Jul 14, 2022 03:55 AM
Subject: Script exist error - "missing close-brace"
Hi
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
