Thanks a lot.
I tested AirRecorder, but get enable handshake errors.
in macos and ubuntu as well.
no clue how to fix this.
my java version:
java version "11.0.2" 2019-01-15 LTS
Java(TM) SE Runtime Environment 18.9 (build 11.0.2+9-LTS)
Java HotSpot(TM) 64-Bit Server VM 18.9 (build 11.0.2+9-LTS, mixed mode)
i get a lot of : Failed to connect: java.io.IOException: Enable handschake failed(1).
also with --disable-fast-login.
java -jar AirRecorder-1.5.5-release.jar -disable-fast-login 192.168.1.xx
any ideas?
