I am trying to build a script that I can use to automate the login and backup of my configs. The issue I am running into is the initial screen gives the HPE warning then says press any key to continue. I added a key stroke to the script but it does not seem to want to run it.
Any suggestions are appreciated
my script is in plain text
show running-config
#BackupAutomation#scripts
