SD-WAN
  • 1.  SD-Branch Radius Authentication with CPPM
    Posted Dec 08, 2023 09:54 AM
    Hey Everyone,
    I know I am probably missing something small on this.  We are working on setting up a new SD-Branch environment, and one of the big things that we have is delivering Vlans/Roles from our CPPM to devices.   I seem to be having some issues with the 9000 devices initiating a radius session with the CPPM on plug in.  Switch wise you of course set this up per port, but it seems you do this per vlan on the gateway.  I have done this, but I am still not seeing any trafffic actually going to the clearpass.
    I have servers and server groups set up
    I have a custom AAA policy set up
    I am using the default MAC auth L2
    I have the AA policy applied to all vlans.
    Any help would be greatly appreciated
  • 2.  RE: SD-Branch Radius Authentication with CPPM
    Posted Dec 09, 2023 07:01 PM
    are the VLAN set to untrusted?
  • 3.  RE: SD-Branch Radius Authentication with CPPM
    Posted Dec 10, 2023 07:39 AM
    The port is trusted and the Vlan has the AAA policy attached to it.
    We have our own auth setup, but I just moved it to default that we set up the same settings to anonomyze
  • 4.  RE: SD-Branch Radius Authentication with CPPM
    Posted Dec 10, 2023 04:52 PM
    if the vlans are trusted, then there will not go through any form of authentication.
  • 5.  RE: SD-Branch Radius Authentication with CPPM
    Posted Dec 10, 2023 06:42 PM
    And that was it.  I knew it was a small thing I missed.  Thanks very much.
