SD- Branch
last person joined: 8 hours ago
SD-Branch VPNC HA
This thread has been viewed 32 times
  • 1.  SD-Branch VPNC HA
    Posted Dec 04, 2023 09:47 AM
    Need help setting up and configuring primary and redundant VPNCs. We are looking to add a 2nd 7010 to DC as a failover. Can anyone help or point me in the right direction to set this up.
  • 2.  RE: SD-Branch VPNC HA
    Posted Dec 05, 2023 03:16 AM
    The SD-WAN Orchestrator Tech Note is an essential document to understand how DC redundancy works and includes several reference architectures:
    https://www.arubanetworks.com/techdocs/central/sd-branch-ref-docs/sd-branch-orchestrator.pdf
    Additionally, the Validated Solutions Guide expands on the topic of Hub designs as well:
    https://www.arubanetworks.com/techdocs/VSG/docs/080-sd-branch-deploy/esp-sd-branch-deploy-040-configuring-vpnc/
    There are some design differences whether you already leverage AOS 10 in your environment or still run 8.x code (that is EoST by end of 2023 by the way). AOS 10 allows you to configure VPNC clustering, where this is not yet possible with 8.x.
    If you need assistance in the actual bring-up of the config, you might want to reach out to a local Aruba partner for assistance.
    I work for Aruba. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or Aruba Networks.
