Wired Intelligent Edge
sd-wan on aruba devices, redundant vpn for cca 80 offices
  • 1.  sd-wan on aruba devices, redundant vpn for cca 80 offices
    Posted Mar 11, 2017 04:14 PM
    have customer running some Cisco gear for VPN towards HQ. Cca 80 offices, small branches, from 5 to 15 users. Right now there is a need to move towards solution which can be easy managed. Customer looking at some SD-WAN solutions and also asked us to see what is avaliable from HPE side in this area. So, what would be best  proposal for this desing in terms of redundancy at HQ (dual internet links) and having braches with one link. One of desires is to have local filtering towards internet (web filter, antivirus) and only business traffic goes towards HQ. QoS is must here.
    Tnx,
    imadam
  • 2.  RE: sd-wan on aruba devices, redundant vpn for cca 80 offices
    Posted Mar 13, 2017 01:29 PM
    AOS 8 has support for "branch-in-a-box". Where the 7000 series controller can act as router / vpn gateway / waas / wireless controller. Also with full support for ZTP over Activate.
  • 3.  RE: sd-wan on aruba devices, redundant vpn for cca 80 offices
    Posted Mar 13, 2017 05:08 PM
    So I put bunch of 7000 at branches and bigger model at hq with what management ?
  • 4.  RE: sd-wan on aruba devices, redundant vpn for cca 80 offices
    Posted Mar 13, 2017 05:20 PM
    Correct... 70xx series at branches using AOS8 and bigger 72xx series serving as VPN concentrators in your DC´s DMZ. Management is done with the Mobility Master.
    You can find the user guide here:
    http://support.arubanetworks.com
    but I recommend reaching out to your nearest Aruba team and have a chat with them about this
  • 5.  RE: sd-wan on aruba devices, redundant vpn for cca 80 offices
    Posted Mar 19, 2017 05:26 AM
    Where IMC Enterprise comes to play or what is future of Aruba management tools since it doesn't make sense to have few tools for same purpose within portfolio?
    Talked to HPE Presales and they proposed IMC instead of Mobility Master.
