SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
SD-WAN VPNC and uplink Health check
This thread has been viewed 47 times
  • 1.  SD-WAN VPNC and uplink Health check
    Posted Mar 04, 2021 01:27 PM
    I would like to know if there is a way to configure health check on VPNC like it can be performed on BGW : Airheads Community
    The goal is to check if next-hop router is UP or KO in order to remove the next-hop in the routing table.
    Best regards,
    guilhem perez
  • 2.  RE: SD-WAN VPNC and uplink Health check
    Posted Mar 04, 2021 05:02 PM
    not to the best of my knowledge. I think this is because, in the VPNCs you can more often use a routing protocol to achieve this.
  • 3.  RE: SD-WAN VPNC and uplink Health check
    Posted Mar 05, 2021 02:32 AM
    There is a LAN Health-check feature on the VPNC that you could use:
    Enabling LAN health check will bring down WAN IPSec tunnels on the VPNC if all route peering is lost on the VPNC LAN - This is done to prevent black holing traffic.
    Also, if the next-hop router fails and thus the peers route updates fail - the VPNC would stop advertising those routes into the SDWAN Overlay. Unless of course there is a broad DC Aggregate that matches an interface on the VPNC.
    Original Message:
    Sent: Mar 04, 2021 10:19 AM
    Subject: SD-WAN VPNC and uplink Health check
    Best regards,
    guilhem perez
  • 4.  RE: SD-WAN VPNC and uplink Health check
    Posted Mar 05, 2021 05:58 PM
    yes you are right, forgot about LAN health check. here is the screenshot for it.
  • 5.  RE: SD-WAN VPNC and uplink Health check
    Posted Mar 08, 2021 02:33 AM
    Thank you for taking the time to answer my question.
    Finally after discussion with Aruba professionnel services, we are going to :
    - Migrate from L2 redundant to L3 redundant architecture + OSPF on the LAN side
    - Direct connection from VPNC to WAN routeurs (in order to detect physical issue)
    This is a huge change for our customer especially with 100 remote sites already migrated on BGW but it seems this is the only way.
    Best regards,
    guilhem perez
