Search by device configuration.
  • 1.  Search by device configuration.
    Posted Jan 25, 2013 01:37 PM
    Is there a way to search by configuration in airwave?
    create a list of all APs using ADP or DHCP?
    I have about a thousand APs I want to import the config from so I can get rid of the mismatched messages but I want to make sure that the configs are the way I want them first.
    We originally had all APs statically set with IP and switch info because there was not DHCP in use in our network.  Now that we DHCP we are switching over to DHCP IPs as well as using ADP.
    Evan
  • 2.  RE: Search by device configuration.
    Posted Jan 25, 2013 06:53 PM
    There currently isn't a search by configuration.  You can submit this as a feature request in the Ideas Portal on the support site.  In the meantime, do you happen to use any of the custom fields in the AP manage pages to assign ADP or DHCP?  If so, they you may be able to find a way to get a list of the APs via a database query.  If not, you might try opening a case with support to see if they can assist in any way.
