Search Clearpass Accounting for specific commands?
  • 1.  Search Clearpass Accounting for specific commands?
    Posted Dec 05, 2018 11:38 AM
    Is it possible to search accounting in clearpass to find commands run?
    Example, a port had a vlan changed and I want to know when that happened.
    Can I tell when that port changed without having to click through each item listed in accounting?
  • 2.  RE: Search Clearpass Accounting for specific commands?
    Posted Dec 05, 2018 11:41 AM
    Assuming you’re talking about TACACS+ Command Accounting? You can run a TACACS+ report in Insight with the raw data and then search the CSV export.
  • 3.  RE: Search Clearpass Accounting for specific commands?
    Posted Dec 05, 2018 12:47 PM
    Yes TACACS+ accounting.
    I did not have insight enabled on my cluster and running a report I don't seem to have any data. Does the insight database only collect information realtime?
    Also, the only Category I found mentioning Accounting was "Accounting - Bandwidth and Session"
  • 4.  RE: Search Clearpass Accounting for specific commands?
    Posted Dec 05, 2018 12:57 PM
    Data is only sent to Insight when it is enabled.
    The TACACS Authentication report with raw data included should include this data.
