Searching CDP Neighbors Information
  • 1.  Searching CDP Neighbors Information
    Posted May 29, 2013 03:31 PM
    Is it possible to search for information within the Platform or Version fields within the CDP Neighbors information?  These fields have some fairly useful information that would be great to be able to search on.
  • 2.  RE: Searching CDP Neighbors Information
    Posted May 29, 2013 04:53 PM
    This should be filed as a feature request in the ideas portal on the support site.  The current search doesn't look at the CDP neighbor table.  In the meantime, for a work around you can query the CDP table from the database and export to excel as a CSV.
    # dbcsv 'select * from cdp_neighbor' >> /tmp/CDPexport.csv
  • 3.  RE: Searching CDP Neighbors Information
    Posted May 12, 2014 08:59 AM
    Rob, Can your database query include the AP name attached to the port listed with the CDP neighbor csv file?
