Secondary 3200 for failover, licensing question
  • 1.  Secondary 3200 for failover, licensing question
    Posted Mar 20, 2013 12:09 AM
    Hiya,
    We would like to operate two 3200 controllers on different sites to backup eachother's APs. One is the master controller of ther other.  I am a bit confused about licenses and AP numbers.
    Controller#1 has 8 local APs
    Controller#2 (master) has 20  local APs and will have 14 remote APs
    Altogether there are 42 APs.
    My questions:
     - could the controllers backup each other?
     - shall we buy 42 licenses for both controllers? (in fact the number of APs remain, only the controller changes)
    I would really appreciate any help in starting me understand "the way of Aruba" as it is not so clear for me. (get used to other vendor)
    Gabor
    #3200
  • 2.  RE: Secondary 3200 for failover, licensing question
    Posted Mar 20, 2013 01:40 AM
     - could the controllers backup each other? YEP.
     - shall we buy 42 licenses for both controllers? (in fact the number of APs remain, only the controller changes) YEP - because if your local will failover to the master,and the master will not have all the needed licesnses to support all the AP'S you will have a problem.
    What i'm trying to say:If the local [with all the lic] will die :smileymad: - all the AP unit [if configured right]  will move to the master or other controller via lms/backuplms and then this controller need to have all the needed licenses for all your aps
    Please download and read the PDF from the following link:
    http://www.arubanetworks.com/wp-content/uploads/VRD_Aruba-Mobility-Controllers_8.pdf
    It will clearly your questions.
    have a lovely week.   :smileyvery-happy:
    Me
    BTW:
    another good VRD to read :smileywink: because i just notice u are using RAP'S
    http://www.arubanetworks.com/wp-content/uploads/rapvrd_version_8.pdf
    An Airhead post - asking almost the same question like you are:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Master-Redundancy-Licensing/td-p/45804
  • 3.  RE: Secondary 3200 for failover, licensing question
    Posted Mar 20, 2013 09:10 PM
    thanks for the prompt reply andfortherightdocumentation. Ihavedownloadedseveralones, butImissedthisone.
    Now it is clear.
    I wish the very best for you!
    Gabor
