Secondary IP address for Aruba7220-US WC
  • 1.  Secondary IP address for Aruba7220-US WC
    Posted Mar 23, 2018 09:16 AM
    How do I add a secondary IP address to a vlan in Aruba7220 Wireless Controller? Is that even a possibility?
    (Aruba7220-US )(config-subif)#ip address 10.36.48.2 255.255.248.0 secondary
    % Invalid input detected at '^' marker.
  • 2.  RE: Secondary IP address for Aruba7220-US WC
    Posted Mar 23, 2018 09:30 AM
    I believe the secondary ip address feature only works on the Mobility Switches.  Are you wanting the secondary IP for management?  If so, you should be able to do that with the loopback address.  I think you can also do that with VRRP groups.  It really depends on what you are trying to accomplish with the secondary IP.
  • 3.  RE: Secondary IP address for Aruba7220-US WC
    Posted Mar 23, 2018 10:43 AM
    This vlan is being used for APs and I need to add 2 ranges to the Vlan.
