Securely attach AP-205H to box?
  • 1.  Securely attach AP-205H to box?
    Posted Nov 22, 2021 10:58 AM
    We have a couple of dorms with 205Hs inside rooms, and those lock on to the mounting bracket with a tiny little screw which is just asking to get lost. (On the 103H mount, there is a clever arrangement where you need to insert a little tool to release the AP from the mount. The 205H is definitely a step backwards design-wise!)
    Does anyone have the specs for the little screw so that I can order a box of spares?
    Cathy Fasano
  • 2.  RE: Securely attach AP-205H to box?
    MVP GURU
    Posted Nov 22, 2021 11:13 AM
    T8H Torx security screw. The replacement wall mount part number comes with the plate, two screws to connect to single-gang box, and the security Torx screw (JW040A AP-205H-MNT1)
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
