Security all wireless office
  • 1.  Security all wireless office
    Posted Nov 26, 2019 06:46 AM
    Hey guys,
    What is the most correct way to secure a small company that wants the best security wireless solution
    I was thinking about 4-6 AP's (303) for 100-150 clients
    Do I need a controller (7005) or something?
    I want to hear your thoughts, maybe you have something else in mind that ו can offer them
    Thank you!
  • 2.  RE: Security all wireless office
    Posted Jan 09, 2020 08:03 AM
    You should start with making a good RF design, this can be done virtual as well with tools like ekahau or visualrf.
    Security on controller based Wi-Fi is not better or worse then Instant, it is just a different deployment model.
    You can choose a deployment model based on customer demands (tunneling needs, local breakout possibility, wired lan integration, cloud or on-prem management.
    Such a small enviroment can usually be deployed with aruba instant.
    Have you discussed ClearPass with the customer, since you are talking about security?
  • 3.  RE: Security all wireless office
    MVP
    Posted Jan 13, 2020 01:37 PM
    I would recommend checking out the ArubaOS Hardening Guide for reference if your focusing on security recommendations / best practices: https://support.arubanetworks.com/Documentation/tabid/77/EntryId/16036/DMXModule/512/Default.aspx
    if your simply looking for WLAN best practices (not just security), you could also breeze through the RF and Roaming Optimization for 802.11ac guide: https://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/508678
