Security for backhaul from additional IAPs in a cluster
  • 1.  Security for backhaul from additional IAPs in a cluster
    Posted Apr 08, 2014 08:12 PM
    First time setting up an IAP and have a couple of questions. I'm planning on setting up an IAP-135 to connect a few laptops in a PCI compliant environment. For range purposes I will likely need a second IAP to connect to the first. From what I can tell the backhaul between the two IAPs will be over 5GHz. My question is what security or encryption is used between the two IAPs?
    Mike
  • 2.  RE: Security for backhaul from additional IAPs in a cluster
    Posted Apr 08, 2014 08:13 PM
    The mesh links are secured with AES encryption.
