Hello!
I've been shown a graph that displays interfering devices in an aruba, like wireless telephones, microwaves and such things, but I am unable to find it myself not that I try to look for it. Where is it?
Can you please supply the OS Version and model of controller that you are running? It may be different menus on different OS's/Controllers.
I am running 5.0.2.0 at a 650 at the moment
What licenses do you have on the controller?
That feature is called Spectrum and is under the license RF Protect. You will also need to have an AP that is capable of support Spectrum. The AP-105, AP-135, and AP-93 all support full Spectrum features. The AP-125 supports a limited set of Spectrum features. You will also need to be running AOS 6.0 or higher.
http://www.arubanetworks.com/pdf/technology/TB_Spectrum-Analyzer.pdf
http://www.arubanetworks.com/pdf/products/DS_AOS_RFPROTECT.pdf
Okay, I need to add licences for it to work then. I'll check the cost of the licence and see if it is worth it.
