Security Training
Select first Match vs Select All Matches ClearPass
This thread has been viewed 16 times
  • 1.  Select first Match vs Select All Matches ClearPass
    Posted Feb 07, 2022 06:03 PM
    Hi All,
    In Aruba Enforcement rules, what is the difference between "Select all Matches" and " Select first match" Algorithm?
    Would really appreciate clear and succinct feedback please.
    Many thanks
    champion nweke
  • 2.  RE: Select first Match vs Select All Matches ClearPass
    MVP EXPERT
    Posted Feb 09, 2022 03:37 AM
    Within the Enforcement Policy, the rules are evaluated from top to bottom in a down fashion. If the First Match is selected, then the first matched will be used and no further rule processing is done. If select all matches is chosen, then all matched rules will be used.
    Craig Syme
  • 3.  RE: Select first Match vs Select All Matches ClearPass
    Posted Feb 09, 2022 06:55 PM
    Thanks Craig
